Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Thanks for the help. Should I go with a .030 head gasket or something else? Been building engines professionally for 28 years so know my way around but Harleys are a little new to me right now. Appreciate the help.
Cometic MLS .030" head gasket. Do not use dowel O-rings and follow Cometic torque instructions.
Would I be better off Picking a different camshaft as well? I mainly ride lots of Twisties and some Highway and to up every now and then
Yes. A coupe you might consider are the S&S570, TMan555, Woods555 or Andrews54. IIRC, the springs on those heads limit lift to .575". If you update springs to later beehives, you could look at cams with higher lifts but without porting, the heads won't be able to take full advantage of the higher left.
