Another 2007 Crank
Feb 11, 2017 | 06:43 AM
Quote:
Originally Posted by
Plated & Screwed
Headed to see the local bottom-end expert today. He has been doing this for close to forty years and has what is needed to confirm my reading.
I want confirmation before going forward.
Great advice!
Good luck with it. Let us know how it turns out.
Feb 11, 2017 | 08:25 AM
Plated & Screwed
I like to think of myself as a "bottom-end" expert
...I'll be glad to help
Feb 11, 2017 | 12:55 PM
martin10
The initial reading taken was off by .0005" Pinion run-out measured with proper device is .0125"
Measured another 2010 crank from a factory 103 with a reported 1500 miles. Run-out at bearing race was .006 on each side. Pinion end was far worse.
Any confidence I had in a factory crank is diminishing. IF anyone has a good one, I am happy for them.
The S&S route with left side Timken upgrade appears to be the best solution.
Feb 13, 2017 | 02:45 PM
Is this was your Bike Mr. Keith, ??
Feb 13, 2017 | 09:19 PM
You bet.If the Timken setup is in the budget, do it. as long as you keep the comp assy torqued correctly, it will run a long time.
Feb 14, 2017 | 06:20 AM
Steve Daniels
"Is this was"??? Not following you there pal, but yes. This is my most recent headache.
Cannonball39
Mar 19, 2018 09:38 PM
OLD 96
Engine Mechanical Topics
Mar 13, 2018 05:53 AM
Krazy8s
Feb 4, 2018 05:08 AM
Cholpin
Exhaust System Topics
Sep 3, 2012 11:20 AM
mgmmgm
Jan 12, 2009 09:26 AM
