motor upgrade
Old Mar 14, 2018 | 02:16 PM
Cannonball39's Avatar
Cannonball39
Stage I
Default motor upgrade
I have a 01 fatboy flstf w/ an 88. I want to change to a 103. What do I need to make that happen ?
Old Mar 14, 2018 | 09:17 PM
langwilliams's Avatar
langwilliams
I'm no expert but I think 103 is out without doing a stroker crank so if you do that go 107....I think the way to go without having to split the cases is to go to a 96 c.i. since your bike is an 01 it has the better lower end (crank/bearings) I'd just do the piston jug swap to a 96 an have the heads done.
Old Mar 14, 2018 | 09:21 PM
Ed Ramberger's Avatar
Ed Ramberger
Need a stroker crank and stroker pistons. 95" and 103" have the same bore. The stroker pistons have the pin bore located in a different location.
88" bored out = 95"
Stroker crank bored to 88" bore = 96"
Stroker crank bored to 95" bore = 103"
Old Mar 14, 2018 | 09:47 PM
cdonis's Avatar
cdonis
Isn't there a 98 kit available. Also may want to look up the HIPPO build. There was a thread not long ago where a forum member basically did a budget hippo build.
Old Mar 15, 2018 | 09:11 AM
tmilo1000's Avatar
tmilo1000
S & S makes a 100 inch kit for the 88 that just involves the pistons and jugs. Don't of anyone that has used this kit or what kind of results you can expect.
Old Mar 15, 2018 | 01:36 PM
Dutch101st's Avatar
Dutch101st
I just purchased an '05 Springer and it has an S&S 98 kit in it...you can look at their site and see what is available...
https://www.sscycle.com/products/98-...silver-finish/
Old Mar 16, 2018 | 12:19 PM
tmilo1000's Avatar
tmilo1000
Would also recommend that if you going with a big bore kit you should also get the heads ported to take full advantage of the bore kit.
Old Mar 16, 2018 | 12:56 PM
Tom84FXST's Avatar
Tom84FXST
Old Mar 16, 2018 | 01:54 PM
FatBob2018's Avatar
FatBob2018
Originally Posted by Tom84FXST
That was genuinely LOL funny.
Old Mar 16, 2018 | 09:54 PM
TriSum's Avatar
TriSum
I have the S&S 100" kit and it is great, lot's of power.
