Piston ring orientation problem?
Old Feb 21, 2017 | 06:15 PM
otto76689's Avatar
otto76689
Default Piston ring orientation problem?
So im in the middle of installing new 10.5-1 comp pistons in my 09 street glide. I installed the rings placed them in the correct orientation per the service manual and installed the piston into the rear cylinder. Now heres my issue, i set the ring orientation to the front piston but installed it in the rear cylinder. The piston is in the right directions just the ring orientation is for the front piston not the rear...Do i need to remove the cylinder and piston again and fix this issue? or can i just do the rear orientation for the front and call it a day
Old Feb 21, 2017 | 06:21 PM
QC's Avatar
QC
Since that's as far as you got, take the jug off and do it right. That way you won't be worry about it.
Old Feb 21, 2017 | 07:28 PM
Max Headflow's Avatar
Max Headflow
Ring orientation really doesn't make any difference as long as they are staggered.
Old Feb 21, 2017 | 07:42 PM
otto76689's Avatar
otto76689
They are absolutely staggered just in the wrong places according to the manual for the rear piston. none of the gaps are over the wrist pin holes. all gaps are staggered in the 2,4,8,10 positions
Old Feb 21, 2017 | 08:07 PM
djl's Avatar
djl
If the piston is in the right cylinder, don't worry about it. The rings are going to move around anyway.
Dustin Miller
Jul 28, 2014 09:58 PM
tanglefootrgu
Exhaust System Topics
Jun 10, 2010 12:50 AM
jslagg
Engine Mechanical Topics
Dec 22, 2008 05:23 PM
Renegade1
Oct 21, 2007 07:55 PM
ranger32@comcast.net
May 29, 2007 07:11 PM
