Pushrod Top Clip Problem
Old Dec 17, 2008 | 03:52 PM
jslagg's Avatar
jslagg
5th Gear
Default Pushrod Top Clip Problem
WTF, I had no problem getting all of them off but now the rear cylinder Clips seems to be tight.....Is there something I need to do that I am just missing something?
Old Dec 22, 2008 | 01:14 PM
rezrider's Avatar
rezrider
Make sure your top tube is seated in the head good. It would be worthwhile to pull it down and make sure your o-ring is in good shape and seated correctly.
Old Dec 22, 2008 | 05:23 PM
miacycles's Avatar
miacycles
Also check the back of the ring and make sure it isn't catching on the cylinder fins as you depress it. Sometimes the pushrod tube deflect inward just a kittke and the ring hangs up. Hope this helps.
otto76689
Engine Mechanical Topics
Feb 21, 2017 08:07 PM
Dustin Miller
Jul 28, 2014 09:58 PM
bustersporty
May 6, 2013 06:02 AM
stevevfd
Dec 23, 2012 06:33 PM
jslagg
EVO
Dec 18, 2008 03:53 AM
