Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hi.
I have an issue with high engine idle. Checking the fault codes, I picked
up a P1034 code (Front oxygen sensor inactive). I re-set the codes, rode the bike but it came back. I would like to know if there is a chance that the issues are related?
I am going to fix the O2 sensor. I just want to know if a faulty O2 sensor can cause a high idle condition. If it can, I will just be re-assured that I am close to resolving the issue.
