Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Has anyone used a woods tw777 in a 103 with andrews +4 advance im thinkin like that to get low end then when i go 107 an ported heads put the stock gear back on (no advance) so i dont have to buy a second set of cams for lots of low rpm torque ? What is everyones opinion on this ? Thanks its a 2015 103 limited twin cooled.
or should i just run the 777 cams straight up an deal with it till i get theads an bore job ? Thanks for all advice it is greatley appreciated!
If you do decide to run them straight up you can always just replace the head gasket with a .030" as well. That'll bump you up to 9.8 on the static compression and then your CCP would be right about 180 PSI which ain't bad. It would perform nicely for a low budget increase. It would be mainly labor and gaskets not a big deal....
i was thinkin the twin cooled was more than that factory suppose to be 10.1.1 or 10.1 from what ive read but im not forsure
