Hollow Exhaust Pop?
Hollow Exhaust Pop?
Hello everyone,
I recently purchased a new to me 2005 Dyna Low Rider FXDLi. This is my first Harley, actually, it's my first road bike so I am trying to learn all I can.
I have noticed when I am driving out of my neighborhood in first or second gear there is sometimes a hollow exhaust pop, almost like a burp out of the pipe if that doesn't sound crazy. It only happens from about 2300 to 2800 RPM. Lower or higher than that and it runs real smooth. Maybe it just doesn't like the speed I'm traveling in those gears?
I plan on purchasing a Power Vision because I think the bike is running lean right now. It has some deceleration pop sometimes. Maybe the exhaust burp is also because it is running too lean right now?
I would appreciate any opinions.
Thanks.
Thanks.
Looks like it's injected and I'm more familiar with carb models but may be an intake leak. If you do a search on Harley Intake Leak Test on youtube - you'll find it's very simple to test (a bit of brake or carb cleaner sprayed at the intake/head interface).
Other than that - it could be tuning for enrich, among other things. What pipes does it have? Free breathing intake?
any codes??? if the IAC is sticking, you maybe getting bleed air and it will cause the mix to go lean. the TPS could have a rough spot in that area which could alter fuel rate. the map probably not but check for vacuum leaks or soft tubing.
happens steady throttle, decel or acel?
Today I was able to change the air cleaner and check for leaks on the intake manifold. I didn't get and changes in the idle when spraying the different gaskets. I still need to look for exhaust leaks. Im starting to wonder if it's a backfire out of the exhaust. I am new to all this so I dont really know what a backfire would feel or sound like.
To answer some some of the questions, it does not matter if it is hot or cold. And my exhaust is an aftermarket exhaust. Tech at the dealership said it was probably a chromewerks set.
While i I was at the dealership getting a new air cleaner I asked about my problem and the tech told me it was a dead spot that the bike has. He said it was no problem. Does that sound like anything y'all have heard about?
After a weekend trip on the bike, the popping started to get worse. I read something that said the spark plugs should be one of the first things checked. I decided I would just change the plugs since I didn't know when they had been last changed. So after putting in some new NGK iridiums, the popping has gone away. The front plug that I replaced was dirty and so I am pretty sure it was causing the problem.
I did also tighten the back exhaust pipe flange because it was slightly loose.
I am now wondering if I should wait to instal a power vision until the winter when I make the air cleaner and exhaust changes I have planned?
usefulshrimp
08-17-2011 11:24 AM
