103 vs. 110
i have a 2014 street glide special and a friend of mine bought a new engine for his 2010 cvo ultra and he gave me his heads and jugs, i was wanting to know how much of a performance improvement it would be to use the 110 heads on my 103 and use my se255 cams or just do the complete upgrade pistons, jugs, cams and heads. any thoughts or suggestions appreciated.
On top of that, the CVO cylinders won't fit on a 103 without some machine work on the cases. The other option is to use the "drop in" cylinders, which have thinner spigots than the CVO cylinders do.
It appears that the OP is letting the availability of free parts drive the build; not a good idea.
Identify the goal for the build, develop a build plan to achieve the goal and let the plan drive the combination of parts required to work the plan. If the available free parts can be incorporated into the build plan, that would be the way to use them but if not, move on.
You can keep your bike a 103 and gain hp and tq by doing head work, 58mm TB and cam swap along with a good tune, that's what I did. Or you can go to the 110 bolt on kit from HD or S&S and gain as well. Lot's of options, 107 big bore is another one.
Go to J&B Performance FB page and look at some of the builds they've done, that may give you some ideas.
Ok, this is what I'm trying to achieve, increased horsepower with great low end torque, any suggestions would be appreciated, the free parts are not a driving factor, those i can sell. just thought since i had them might as well try to use them, but if they are not what i need then that isn't a factor. thanks
