A Conversation on the effects of header pipe diameter.
Exhaust gas velocity is a critical parameter to engine tuning.
Exhaust gas velocity is one of the two controlling factors of the exhaust reversion wave. Smaller diameter tube has higher velocity given same exhaust gas volume. Length of exhaust tube is the other factor.
Exhaust reversion wave will scavenge combustion chamber IF reversion wave arrives at exhaust valve at correct time.
Exhaust reversion wave can be controlled by exhaust gas velocity and exhaust tube length.
Larger diameter exhaust tube comes into "tune" at a higher rpm than smaller diameter tube of the same length.
Practical applications are Ford "high-velocity" exhaust ports (read smaller area but higher gas velocity) and "long-tube headers" (again smaller diameter but longer length). Both applications increase low rpm torque values.
(We did this fifty years ago on the Can-Am cars)
Now given the dyno charts posted comparing the 2-2 small diameter Vs the 2-1 with a larger diameter primary tube, I wonder what would happen to the torque curve, particularly that dip at about 2700, if the primary tube was smaller, even if it only for the first 10-12" of header length.
But not a valid comparison as one is SAE corrected and the other is Actual.. Also more to the pipe then just header diameter. Curve wise, I like the python better.
Yeah I know the differences in the run sheets, I was just trying to generalize the difference in the way the torque curve is...
FLS103
2018+ Softail Models
11
07-01-2019 07:03 PM
