Shovel head won’t start
Hey everybody I’ve recently got my first Harley (1981 shovelhead) in 2017, put away for the winter and come spring and does not start. It cranks but won’t start. Replaced the spark plugs and some relay found by the battery but still won’t start. I don’t hear the fuel pump turn on when I turn the ignition to the start position. And doesn’t sound like it wants to start at all. I’m thinking it may be a electrical problem, but cannot find any kind of fuse box on it. Btw the relay I replace was right by the battery. Any thoughts on what I should do?
Welcome from Houston Texas!
Well i am not the authority on the subject but, when i start mine (cold, not wormed up) i
turn on the petcock (left side below the gas tank) make sure engine kill button is in the run position and if it has a SnS carburetor on it, pull up on the choke (for lack of better word), its on top of the carburetor if its stock it could be in the same place or somewhere else on the carburetor, open the throttle all the way twice, and hit the start button.
Its not fuel injected so you wont here a fuel pump kick on when you turn the key.
Hi from the UK and welcome to HDF. I bought a new Shovelhead, back in 1974, although it is a long time ago since I sold it.
You really need to get better acquainted with your bike! It doesn't have fuel injection, as SD points out, so you won't hear a pump. If stock or close to stock, your bike doesn't have any fuses, it has circuit breakers instead, small aluminium boxes roughly the size of a relay. I recommend you buy the genuine factory manual, which you can get from a local dealer or on-line discount dealer. If your handlebar controls are stock, then your kill switch is on the righthand handlebar. Assuming your bike was running fine when you last rode it do NOT top up the oil, especially if low. What was there last season may now be in the crankcases and adding more will add to your woes!
We have a dedicated Shovelhead section, where you may find better help.
Received 1,061 Likes
It would not crank if that relay was bad or the kill switch was off.. Check for spark, pull 1 plug put the wire back on, make sure the threaded part is touching ground,bare metal not paint, then crank. A spark should be observed when cranking. If it was running ok before storage I wouldn't worry about timing just yet.
rs1250xl
09-21-2016 03:49 PM
