Turns over. Won't start!
Old Dec 18, 2011 | 01:04 PM
LTDHOG's Avatar
LTDHOG
Default Turns over. Won't start!
My 2012 Flhtk won't start. Turn on the ignition, but when I flip the switch the fuel pump does not turn on. Then just turns over no start. Any ideas?
Old Dec 18, 2011 | 01:14 PM
mkguitar's Avatar
mkguitar
check fuses?
mike
Old Dec 18, 2011 | 01:17 PM
speedwaysteve's Avatar
speedwaysteve
With a 2012 bike i would hope the dealer would pick it up and fix it for you right away
Old Dec 18, 2011 | 01:18 PM
Stash's Avatar
Stash
Its a brand new bike. DEALER!
Old Dec 18, 2011 | 01:23 PM
skully1200's Avatar
skully1200
My first thought would be fuse. Of course any time a fuse blows, I have to wonder why.
Old Dec 19, 2011 | 11:22 AM
LTDHOG's Avatar
LTDHOG
Checked the fuse... It's good. This is not the fisrt time... Happened first in Utah. I pulled the seat and just wiggled connections and it worked. A week later at home it did it again. I did the same procedure and rode to the dealer. Of course, they could not get it to fail. Now, about a month later. Same thing. This time none of my usual fixes worked. I'll have them pick it up Tuesday am and let you know.
Old Dec 19, 2011 | 12:16 PM
mkguitar's Avatar
mkguitar
if you have any add on tuner to the ECM remove it- try again.
Mike
Old Dec 20, 2011 | 11:10 AM
LTDHOG's Avatar
LTDHOG
No tuner yet. It's off to the dealer this morning. Thanks for the idea...
Old Dec 20, 2011 | 11:30 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Give it back to the stealer and get a new bike if they can't fix the problem!
Old Dec 21, 2011 | 01:51 PM
beautifulbob's Avatar
beautifulbob
Stage I
Default I had the same problem
My 5 month old road king would kick over but not start. Harley assist towed it to the local dealer. Turned out the battery had enough charge to turn it over butnot enough to start it. They replaced it under warranty and its as a goodas gold.
