OEM Valve guide OD SIZE?
Old Nov 27, 2018 | 09:48 AM
T.gomer55's Avatar
T.gomer55
Default OEM Valve guide OD SIZE?
Replacing valve guides in my 14’ twin cam and trying to figure out what is the OD of the valve guides that are in it, anybody help me out? Some say +1 or +2 and some just say STD but want to make sure I get the right ones.
Old Nov 27, 2018 | 01:10 PM
bustert's Avatar
bustert
hard to say installed. if the machine never had work, there is your answer. if not, probably will have to remove them.
if you are replacing, do not buy till you have the old guides out so you can measure both the guide and bore. if you heat the head in an oven to 400*f, they will come out easily and sometimes, they do not remove material so a std guide fits without issues. just let the head cool naturally in the oven without heat.
have you measured stem clearance? a lot of people scoff at knurling but you can extend the life of your guide that is in the head. like an oil debate, some say it will last longer due to the voids holding oil, but it has been around practically since internal combustion engines have been around, did a few myself on blocks where the guide is the block.
Old Nov 27, 2018 | 04:25 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
While I cannot give you the proper size I like to remove the old first to see what's needed, then get the correct ones. I just run a drill down the guide that will leave about 0.030 - 0.040 thickness left of the old guide. Then you can tap the left over part out without any materiel being pulled from the head itself.
Old Nov 27, 2018 | 07:14 PM
Max Headflow's Avatar
Max Headflow
The guys I know that port heads typically drive +1 guides into stock heads that have not been handled previously. I've been doing it without issue. (2-3) sets.. Stock hole size is 9/16..
Old Nov 27, 2018 | 11:50 PM
T.gomer55's Avatar
T.gomer55
Thanks all for the replies, I’m shadowing the guy who works on my bike and just trying to make sure I get the right guides n seals. Decided to jus go with OEM from the dealer since it was quick and military discount
Old Nov 29, 2018 | 05:48 AM
prodrag1320's Avatar
prodrag1320
use a +.001 guide,i have to ask though,why are you replacing them? plus you do realise the guides will need to be honed to size & seats will need to be cut after install,right? really best left to a shop with the proper tooling & experiance
lmz5150
Shovelhead
Jul 2, 2019 11:10 PM
65Tiger
Engine Mechanical Topics
Jun 5, 2017 10:57 AM
tubeman426
Exhaust System Topics
Jan 11, 2013 03:16 PM
teaguerr
Dec 15, 2012 09:36 PM
Low_SG_rider
Nov 4, 2007 05:54 PM
