head milling calculator
Old Jun 3, 2017 | 08:59 AM
65Tiger's Avatar
65Tiger
Default head milling calculator
103" Twin Cam heads with ACR
I am familiar with the Big Boyz head porting calculator and how to calculate combustion chamber size to achieve the desired static compression ratio
Is there a calculator for how much to mill the head for a Xcc reduction in chamber size?
These are spare heads and the ACR's are out.
Does installing the ACR change the combustion chamber volume and how to measure volume with this hole in the chamber?
Old Jun 3, 2017 | 09:18 AM
Max Headflow's Avatar
Max Headflow
The rule of thumb on a standard combustion chamber shape for twincams is 0.007" of milling removes 1 cc from the chamber.
You need to plug the hole.. Modeling clay work. 12 x 1.25 mm bolt and some grease.. Anything.. Only need to hold liquid long enough to make the measurement..
Old Jun 3, 2017 | 10:27 AM
djl's Avatar
djl
Somebody else did the math.
Old Jun 3, 2017 | 01:00 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
No to be a kill-joy, but we use .006" here.
Cut, cc, cut, cc, until you've established the desired volume.
Scott
Old Jun 4, 2017 | 10:17 AM
65Tiger's Avatar
65Tiger
Scott
Which is why I asked as it is not a simple formula as the chamber and volume shape will change as one cuts.
My other bike has Husquavarna pop up type manual compression releases, and I have never seen a head with ACR's, so unaware if the ACR when installed changes the volume
Will simple plug the hole flush then
Old Jun 4, 2017 | 04:28 PM
djl's Avatar
djl
Scott's way is more precise; however, the figure provided in #3 will get you close enough; the main thing is to equalize the chambers. CCP and corrected CR are going to be much more effected by head gasket thickness, squish, deck height and intake valve close timing. Accuracy on those elements are much more important than being off a fraction of a CC on chamber volume.
BTW, I have only seen a couple off sets of the ACR heads and the ones I saw, the ACR finished very near flush with the chamber surface and so do the plugs HD sells to plug those holes.
Old Jun 5, 2017 | 10:57 AM
prodrag1320's Avatar
prodrag1320
I would never mill heads from some "formula",as Scott said the proper way to do it,same as it's done here
muskwa
Engine Mechanical Topics
Dec 6, 2016 09:05 AM
JKSHYT
11
Mar 19, 2014 06:57 AM
hdrk07_61
Exhaust System Topics
Sep 17, 2008 10:04 PM
sporty2003
Dec 21, 2007 10:41 AM
camaroman7d
May 21, 2007 01:16 AM
