The MOCO NEW Extreme Flow 55mm Intake Manifold
So this is the description from the MOCO website:
This Screamin’ Eagle® 55mm Extreme-Flow Intake Manifold features enhanced, 55mm, air-guzzling geometry and hand-polished intake runners to provide uninhibited airflow to the engine resulting in a 2% - 4% increase in horsepower that you will notice.
Secondly and most important to me, the Powervision, FP3, and other well known tuners are all tuning with the OEM intake manifold size, so If someone were to get this put on, you would almost certainly HAVE to go full on DYNO. Right? or how could we make sure the proper tune is being ran?
thanks
- Cast-aluminum construction withstands sustained high-engine temperatures for reliability even under the harshest riding conditions
- Fits the stock throttle body and all Screamin' Eagle® Intake Kits
- Works with all current Screamin' Eagle® Pro Street Tuner calibrations
- All models require ECM calibration with Screamin’ Eagle® Pro Street Tuner for proper installation
- 50-State U.S. EPA compliant
thanks
We actually test the air flow here.
Some gains to be had as shown on our SuperFlow 600, flow bench.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
So just an update. I found the leak around the rear intake seal. now some may not know but the M8s intake manifolds are polymer/Plastic and my dealer has had at least 3 that they have had to warranty due to cracking and or leaking. Mine had about 6k on it but the leak i know has become worse over time, but this year it was really bad. So instead of putting the OEM plastic intake manifold back on, i opted to put a metal one on, the 55mm HD extreme flow in the photo above. Well the leak is gone, no more popping, or weird idle issues. AS for performance, nothing to note by seat of the pants. If there is any perf gains, the only way to know is to test it on dyno or other machine.
A tech on another forum has reported seeing at least two of the plastic manifolds melt.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
