Headwork first or pistons first?
Old Jan 6, 2021 | 05:04 PM
tinymike66's Avatar
tinymike66
Default Headwork first or pistons first?
So do I get my heads done first or do I buy my pistons first?
Sorry if it's a dumb question , but I been learning a crazy amount talking to some reputable people here. So I'm trying to absorb as much as I can.
Old Jan 6, 2021 | 05:06 PM
Rogue1's Avatar
Rogue1
If you're going to do them both, why can't you do them both at the same time?
Old Jan 6, 2021 | 05:08 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
BINGO!
Why go under the knife twice? If money is a issue. Wait till you have enough for both.
But, Your Bike Your Money...
YB
Old Jan 6, 2021 | 05:21 PM
tinymike66's Avatar
tinymike66
Originally Posted by 09 YELLOWBIRD
BINGO!
YB
Lol....no no no...not what I mean.
I have to order the pistons and send heads out
Question is what do I base it on...do I order pistons according to what specific work I'm doing to heads
Or
Do I request specific headwork based on what pistons I ordered etc
Either or I need 10.5:1 or 11:1 cr
Old Jan 6, 2021 | 05:30 PM
wright111's Avatar
wright111
Or
I would call fm great ppl just did stage 2 with them
Old Jan 6, 2021 | 05:39 PM
djl's Avatar
djl
Cam first; then build around the cam. You could have heads done first, keep OEM chamber volume but equalize, have them machined for compression releases, etc. then select a cam and working with cam specs and chamber volume work out if pistons should be flat top or domed and if domed, how much dome. If the OP does heads/pistons without cam specs, cam selection will be limited.
Old Jan 6, 2021 | 05:46 PM
GearheadMike's Avatar
GearheadMike
It is a symbiotic relationship. You need to talk with your head porter about the pistons. He will base the headwork on what you want to do. You want stock pistons, fine. You want high compression, domed pistons, fine.
The heads can be customized, the pistons so much.
Old Jan 6, 2021 | 05:49 PM
09 YELLOWBIRD
Or
Gotcha!
What part of the country are you from? Lots of great engine builders on this site and others around the US. Any Good Engine builder will direct you in the right direction.
Also what size motor currently?
* What DJL said makes sense as well.
YB
Old Jan 6, 2021 | 06:08 PM
eighteight's Avatar
eighteight
Or
you previously stated that you had SE small chamber heads and were speaking to weisco for compatible pistons to accommodate them
Old Jan 6, 2021 | 06:39 PM
tinymike66's Avatar
tinymike66
Currently I have SE 257 cams
They were installed 6000k ago.
The heads I have are SE pro.performance 76cc
the heads are already machined for compression release valves
SE cam plateHydrolic tensioners
Rienhart 4" 2 into 1 exhaust
It's 2001 ultra stripped down just a little
