Headwork first or pistons first?
Old Jan 7, 2021 | 03:26 PM
marcodarq's Avatar
marcodarq
did you do the install yourself, or pay a shop to do it? the reason i ask is if you did it yourself i would hope that you checked and measured a few things.....what head gasket thickness did you use, what was your valve to piston clearance? what was your valve to valve clearance @tdc lifts? having this sort of info available while the bike is still running can help you to make decisions about what you have to do later. recording all this type of info during the course of the build is invaluable!!
m
Old Jan 7, 2021 | 03:35 PM
tinymike66's Avatar
tinymike66
m
It's still apart
These are the pieces of puzzle I'm getting at. Hence the persistant ongoing questions. I will not begin to install until I have all the info I need
Old Jan 7, 2021 | 06:19 PM
djl's Avatar
djl
Originally Posted by tinymike66
CCP was @185
Something doesn't compute here; 76cc heads and SE hi comp pistons, 257 cams and CCP @ 185psi; not adding up. We need details to help; flying blind at the moment.
Old Jan 7, 2021 | 06:36 PM
tinymike66's Avatar
tinymike66
What info u need?
I'll do my best to fill u in.
To test I removed spark plugScrew in tester
Opent throttle all the way then cranked engine over four or five times
Pretty sure it peaked at 185
Old Jan 7, 2021 | 07:21 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I put him with stock flat tops and I get 184 ccp.. I did not see where he stated as he has SE high compression pistons...
Old Jan 7, 2021 | 08:09 PM
tinymike66's Avatar
tinymike66
Maybe it was 195 psi
i did I a while ago...**** I should have written it down ugh
Old Jan 7, 2021 | 08:11 PM
tinymike66's Avatar
tinymike66
I mentioned it...they are the 1550 high comp Pistons with 8cc dome.
.30 gaskets
Old Jan 8, 2021 | 10:28 AM
djl's Avatar
djl
I mentioned it...they are the 1550 high comp Pistons with 8cc dome. .30 gaskets
Like I said, that doesn't match up with 185CCP; CCP should be 200+psi with that combination.
Old Jan 8, 2021 | 10:52 AM
smitty901's Avatar
smitty901
Originally Posted by Tarheel Leo
If you're going to do them both, why can't you do them both at the same time?
Yes. get all the work done same time same place
Old Jan 11, 2021 | 12:41 PM
tinymike66's Avatar
tinymike66
Ok...so lots of incoming info...quality info.
Scott, Kirby and others to mention with amazing advice.
Bottom line obviously is what am I looking for
So here goes
id like to see around 100+ HP and 100+ torque
The ideal range especially for the torque would be 2500rpm to 6000rpm
I've decided I'm willing to change my cams to achieve this
im also willing to do some head work, but nothing overboard.
A. What cams yield such outcomes? Or closest too?
B. Exactly what should I do to heads...mind you I'd like to leave the chamber's at 76cc if possible.
C. Can I achieve these #'s at 95ci or do I need to go to 98ci?
LowRider68
Mar 6, 2015 01:10 PM
texashillcountry
EVO
20
Jan 18, 2014 08:49 AM
Blu02
Dec 3, 2010 07:01 PM
Crazy Canuck
Exhaust System Topics
Oct 5, 2007 09:52 PM
dawg
Dec 12, 2006 08:30 AM
