Possible Cam Swap, advice needed
While i'm in my cam chest replacing the cam plate and oil pump, I'm looking at possibly swapping out my Tman590s to a set of Wood tw400-6s. My goal is to achieve maximum off the line torque. Would it even be worth the potential gains?
Zippers 117", 10.8-1, 58mm TB, 5.3inj
By going to the 400-6 it will move the torque curve a little to the left. I don't think it would be a value though. You might want to look at the 408-6. I think it would be a better improvement over the other 2 cams.. Best to call Scott at hillside, I know he loves Woods cams.. Also believe it's a better move because of your 10.8:1 static..
brownie4412 (02-24-2021)
I will say this, the 400 ramps are VERY aggressive and can be 'sewing machine' noisy.
Scale the squeeze back a tick and those will work, as will the 408-6, and/or a T-Man .660-PS-2.
Our Sport-Touring 117"s here, receive a Wood 9F set at the proper compression, big, broad torque.
They run very well.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
