Rocker arms
Old Oct 16, 2021 | 01:57 PM
maverickfe's Avatar
maverickfe
Default Rocker arms
Hello im thinking of putting in roller rockers just seeing what your thoughts are and if so what kind?
Old Oct 16, 2021 | 02:06 PM
djl's Avatar
djl
It would help to know more about the application, like model make and year, previous modifications, etc.
As a general rule, unless cam lift is greater than .600" lift, the OEM rockers are adequate. Add to that the roller rockers are nosier than OEM rockers and my advice would be to save the money and spend it on something that will enhance performance; roller rockers are not cheap. As far as what kind, do the homework and buy what floats your boat. The only ones I have run are the HD rollers and, IMHO, they are as good as any.
Old Oct 16, 2021 | 02:31 PM
maverickfe's Avatar
maverickfe
its a 2000 fatboy cv carb Andrews Conversion Camshafts - Size 26N bassani exhaust.
Old Oct 16, 2021 | 02:43 PM
marcodarq's Avatar
marcodarq
dont bother,,,if you do for some reason only se Jim's or S&S.
m
Old Oct 16, 2021 | 03:12 PM
djl's Avatar
djl
If you have the $$ for a set of roller rockers, save another couple of hundred $$ and have your heads ported to Stage I and springs replaced to accommodate .600" lift cams if you plan on more performance down the road. Specs say the '00 valve springs will only accommodate .500" cam lifts; however, some have run .510" and .525" without issues but that is the max. Use a .030" head gasket when re-assembling for a compression boost.
You did not say if motor is TC88 or has been bored but if 88", lots of rooom for growth.
Old Oct 16, 2021 | 07:09 PM
maverickfe's Avatar
maverickfe
the engine is a 2000 tc88 i have bought 2006 heads for it that have the bigger vales in them
Old Oct 16, 2021 | 07:27 PM
Ed Ramberger's Avatar
Ed Ramberger
How nosey are they? Like Gladys Kravitz nosey???
Old Oct 16, 2021 | 09:17 PM
maverickfe's Avatar
maverickfe
no not yet i have to change out my cam plate and cams so i was just while i have it all apart to do them
Old Oct 17, 2021 | 05:20 PM
djl's Avatar
djl
I had to Google Gladys Kravitz to respond. I guess I need to sharpen my typing skills.
Old Oct 17, 2021 | 05:23 PM
djl's Avatar
djl
I will leave the proof reading and spelling correction to Ed. The 2006 heads do not have bigger "vales"; however, they do flow better than the earlier heads.
