Throttle bodies
Old Dec 21, 2021 | 02:05 PM
harley#1's Avatar
harley#1
Default Throttle bodies
Hey. I have a 09 classic. It came with a 27685-08A T/B .I replaced it with a 27685-11 this summer because of stripped plastic gears. Didn,t know if it would work right but it worked great. I got a chance to buy a 27685-11A just to have but not sure what the A means. need help. thanks.
Old Dec 21, 2021 | 04:06 PM
60Gunner's Avatar
60Gunner
Updated version.
Old Dec 22, 2021 | 07:25 AM
harley#1's Avatar
harley#1
I took a chance on the 11 and found no difference in performance thankfully, so wondering if im pushing my luck with a 11 A .if there is a difference i would like to know before a purchase. thanks.
Old Dec 22, 2021 | 03:57 PM
djl's Avatar
djl
Don't know what the difference is between -11 and -11A but maybe the plastic gears were replaced with better material? Isn't that what the MoCo does? Replace a weak part with something more durable? The A is an upgrade, not larger or smaller but whatever was changed should not have an effect on power delivery.
Old Dec 23, 2021 | 02:18 PM
harley#1's Avatar
harley#1
typical mo co. will only fix its flaws when enough of us complain. As long as the wire plug in the side is the same, hopefully everything else will work. the 11 version looks exactly the same as the 08A and works the same. thanks.
conmore
Feb 2, 2012 08:17 PM
powerlab
Dec 25, 2010 08:13 PM
cowboy0707
Sep 13, 2010 08:58 AM
HogFather
Jul 8, 2009 07:57 AM
paulies 07
Nov 13, 2008 09:37 PM
