Question about the screaming Eagle adjustable pushrods.
Old Feb 7, 2022 | 09:28 PM
JP7's Avatar
JP7
Originally Posted by QC
Are the standard SE and the Quick different TPI?
They both have the same installation instructions. Which says 2 1/2 turns which would be .104”.
Fuel Moto recommended I go .140” deep. This is the second set I’ve installed at 3 turns and 2 flats and the valve train has been quiet.
Old Feb 7, 2022 | 09:29 PM
Screamin beagle's Avatar
Screamin beagle
theres only one type of screaming eagle pushrod...no such thing as standard or quickie...thats for s&s. What depth should screaming eagle lifters be set at??? I'd say at the deepest part of the garbage can. But to actually answer a question and try to be helpful I've run screaming eagle pushrods on s&s lifters, Larry's machine lifters and woods and set all of them at 3.5 turns and everyone has been completely happy.
Old Feb 7, 2022 | 09:37 PM
JP7's Avatar
JP7
Kwikwilson007 for your piece of mind set them at 2 1/2 turns which is .104” and try it. If the valve train is noisy it’s not much work to go back in and add 5 flats to get you to .140” preload.
Old Feb 7, 2022 | 09:56 PM
QC's Avatar
QC
Thanks for the info.
Old Feb 8, 2022 | 04:11 AM
mthopton's Avatar
mthopton
Good information in this thread.
Old Feb 8, 2022 | 05:34 AM
Kwikwilson007's Avatar
Kwikwilson007
I’m doing a repair on an existing build and when I took them out , I counted the turns as I was loosening them . They were set at only two turns . This is what was causing the confusion.. I don’t think they were set properly to begin with . At only two turns I’m wondering if the valves were opening completely.. I’m gonna go with what you suggested.. The 2 1/2 is a safe bet and if I’m getting any noise . I’ll just go back and add 5 flats . Thanks guys . you have All been very helpful…
Old Feb 8, 2022 | 06:32 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Most lifter plunger travel is 0.200. There is a slight bleed down thru a cycle of the engine camshaft. Lifters are little hydraulic jacks but they are not strong enough to override valve springs.
Staying in the 0.100 range in on the lifter works. That gives you 0.100 on each side for length expansion difference in cylinder and pushrod differences. The 0.100 is like a mile compared to what the cylinder and pushrod change.
What makes noise sometimes is when you have heavy springs and wild cams that do not have a couple degrees of increase in base circle diameter before the start of the lift to take care of the slight bleed down.
If a little noise bothers you, don't make a full race motor.?
Sparra
Engine Mechanical Topics
Aug 16, 2018 12:08 AM
maddghost
May 30, 2017 08:11 PM
800screws
EVO
Nov 4, 2016 10:58 AM
cruzmisl
Touring Parts
Sep 24, 2011 07:47 PM
spirit80
Mar 6, 2008 10:29 AM
