Lifter Holders
Old Oct 27, 2022 | 05:12 PM
Lammy1000's Avatar
Lammy1000
Default Lifter Holders
Hey everyone, Looking forward to starting my stage 2 project. Nearly stock 2020 Sport Glide w/107ci, 25,000mi being upgraded to Woods WM8-22X cam and alpha lifters. I would like to keep tappet covers in place, removing lifters via cam chest. Are magnetic tappet holders required for this?
Old Oct 27, 2022 | 05:40 PM
RFG7680's Avatar
RFG7680
Yes. You’ll need something to hold them up while you put the cam in. Why are you against removing the tappet covers? I would anyway to upgrade from plastic tappet guides to the aluminum ones.
Old Oct 27, 2022 | 07:19 PM
Max Headflow's Avatar
Max Headflow
Can you change the inner lifters by dropping them out the bottom?
Old Oct 28, 2022 | 11:17 AM
Lammy1000's Avatar
Lammy1000
I was seeking to avoid issues with the tappet cover bolts breaking. Sounds like some heat and working the fasteners slowly is the best path?
Old Oct 28, 2022 | 12:01 PM
RFG7680's Avatar
RFG7680
Yes. I did mine. No heat. Just slow pressure and no issues. I have seen people with them snap. Fuel Moto makes a kit just in case that happens on the tappet guide bolts. As far as the tappet cover bolts. Slow and easy. But I understand your apprehension.
Warning. Sticker shock.
https://www.fuelmotousa.com/i-23899905?q=Tappet
UrbanRunner
Milwaukee Eight (M8)
25
Aug 12, 2021 08:33 PM
Lammy1000
15
May 6, 2021 05:27 PM
Alienwulf
Engine Mechanical Topics
Jan 10, 2016 10:16 AM
steelpony16
Aug 7, 2013 06:25 AM
The Roadrunner
Dec 10, 2011 11:42 AM
