SE204 Cam Swap
Old Feb 23, 2024 | 11:23 AM
PureHybrid's Avatar
PureHybrid
Originally Posted by djl
More displacement but don't stop at 95", same $$ gets 98". Be careful of compression with the 204s; they won't like much more that about 9.6-9.8 static. If funds are available, the early heads need improvement. Plenty of places to have them worked BigBoyz, Hillside Cycles, WFO Larry, AKA Larry's Motorcycle and Machine and HD Street Performance are a few that come to mind. A dyno tune will be necessary with any of the above modifications.
Could always throw a -4 sprocket on there
Old Feb 23, 2024 | 01:51 PM
tdrglide's Avatar
tdrglide
I ran the SE204 in a 09" 96" streetglide. I know, slightly different motor, but was otherwise stocker with bub slip on mufflers and SE air cleaner. IIRC, made ~90 hp and high 90s tq. Nice lope to idle. The 204 has a lot of ground in advance but I'd run it straight up. Nice cruiser
Old Feb 23, 2024 | 02:26 PM
djl's Avatar
djl
Similar experience in a 95" back in the day; BB "street port", V&H Side Shots, 104TQ/94HP. BB's heads probably didn't flow much better than the later '06 heads and the Side Shots were a poor choice but the bike was fun to ride solo; two up needed more off idle TQ. South Texas heat brought out detonation with 190psi CCP and I had to replace the cam. We tried pulling timing but that just turned the bike into a turd. I still like the cam though; just have to set it up right and not expect more than it can give.
RoadTrain22
Engine Mechanical Topics
Aug 13, 2022 06:32 PM
shoboli nan tanna
Aug 13, 2021 09:51 AM
JDB
Aug 7, 2011 01:48 PM
cwilks
Apr 14, 2007 11:36 AM
hawnstar
Feb 6, 2006 04:17 AM
