So I did the unthinkable today-
Old Jul 12, 2024 | 02:58 PM
Sandbag808's Avatar
Sandbag808
3rd Gear
Default So I did the unthinkable today-
So yes, I tried it. While installing new lifters and the quickie pushrod kit, my engine bit off a large piece of chopstick that I had stuck into the cylinder to find TDCC. Actually it was both cylinders, according to my little earwax camera. After trying everything under the sun to get them out, I saw a piece stuck inside my exhaust valve with the camera. So I said, well if I’m going there anyway, I might as well go in-style! I started that MF up and aside from burnt wood smell coming from the exhaust, it still runs like a champ.
I know I’m not the only one who has thought about this so I just thought you outta know…
Old Jul 15, 2024 | 11:32 AM
xcbullet's Avatar
xcbullet
I got lucky with a spray straw once. It was all in and I was about to give up and tear it apart. Then I rolled motor over one more time and it showed itself right in the center of the spark plug hole. With large tweezers I clamped down hard and yanked it out.
Old Jul 15, 2024 | 02:17 PM
Tommy C's Avatar
Tommy C
You guys realize that there's no need to be putting foreign objects in the spark plug holes to adjust the valves. Watching the position of the lifters when rotating the crankshaft is a much better method. Adjust the intake pushrod as the exhaust is just starting to open and adjust the exhaust pushrod as the intake has just closed.
Old Jul 15, 2024 | 04:37 PM
nutsandbolts5212's Avatar
nutsandbolts5212
Get a long straw from one of those fast food dumps, take your time and you'll never have a problem. Got three in my tool drawer for this type of work.
Ride safe!
Old Jul 19, 2024 | 02:32 AM
Vza's Avatar
Vza
I pulled my plastic chopstick that broke off with flex retreval tool ...took a while and patients you ll get it though.
Old Jul 22, 2024 | 01:29 PM
I Like Pie's Avatar
I Like Pie
I love the smell of campfires.
Old Jul 22, 2024 | 10:42 PM
Max Headflow's Avatar
Max Headflow
Why are you sticking a chopstick in the plug hole?? Want to sample the carbon? Use a straw and snort it..
Old Jul 22, 2024 | 11:03 PM
PeterB's Avatar
PeterB
Use a screwdriver with big enough handle that won't go down the plug hole.
Old Jul 23, 2024 | 12:03 AM
Bent and Broken's Avatar
Bent and Broken
I like a bike story with a good ending.
Old Nov 2, 2024 | 12:11 AM
fhansen's Avatar
fhansen
I rigged up a small tube to the shop vac and pulled three short pieces out that I had spied with a camera. Made my day.
Theheretic
Aug 13, 2020 10:30 PM
ghost183
Screamin Eagle CVO Models
Jun 3, 2019 04:07 PM
Pro1079
Engine Mechanical Topics
Nov 23, 2017 07:14 AM
Rusty Axle
Shovelhead
Jun 3, 2017 07:29 PM
rguilbert
Jun 2, 2008 10:35 PM
