Screaming eagle factory 110B upgrade
Old Oct 17, 2025 | 06:35 AM
Timh1797's Avatar
Timh1797
1st Gear
Originally Posted by Hilly13
I have a 110B in my 16 Slim S, it's had a few cams in it, many different exhaust configurations, a couple of intakes and throttle body's, I like or rather liked to play around with combos, waste of money really but so is pissing it up against the wall, my heads are stock and it's hard on lifters, even expensive lifters, lots of things are written on the internet by well intentioned people that perhaps should come with a disclaimer along the lines of I have no idea what I'm talking about, you need to reset or you will spend dollars on disappointment, marc gave you some decent tips, ring and talk to them, they do it for a living and will steer you right and you don't need the plate and pump.
Good luck with your mods and tune, let us know how it pans out.
Appreciate that. So what do you think of this new one i configured.
Camshaft Zipper’s Red Shift 587 Bolt-in, quiet lobes, perfect mid-range for 110BCylinder Heads Ported OEM 110
Heads – Zipper’s or Fuel Moto Increases flow + efficiency; +10-15 HP gainHead Gaskets Cometic .030″ MLS Slight compression bump (~10.3:1)Throttle Body 58 mm HPI or Screamin’ Eagle Higher airflowAir Intake S&S Stealth Air Cleaner Proven high-flow designExhaust D&D Fat Cat 2-into-1 (quiet baffle) Superior scavenging + midrange torqueTuner ???
Old Oct 17, 2025 | 07:21 AM
Hilly13's Avatar
Hilly13
I'm not familiar with the cam, have you seen anyone else running it? Popping heads just for gaskets, I wouldn't but not saying don't, the SE58 works well, the fatcat is a proven pipe, the stealth are well built and flow enough for this in my understanding, don't forget lifters and adjustable push rods, the tune is what will tie it together, a chat on the phone with a guru will shuffle it all into place.
Old Oct 17, 2025 | 07:51 AM
marcodarq's Avatar
marcodarq
Your last posting is a much better plan!!
I have installed and tuned 3 of that Zippers cam and it works as advertised. The ported heads are a go, and the fat cat us a personal favorite of mine for TC snd Evo bikes.
Much better plan, i know from experience.
m
Old Oct 17, 2025 | 08:22 AM
Fat11Lo's Avatar
Fat11Lo
I used that 587 cam in a friend's 2016 Street Glide, dramatically improved torque, Zippers sold him a Thunder Max tuner but we will be replacing that with the stock ECM and a TTS, with a proper dyno tune over this winter
Down South
49
Jul 12, 2024 09:14 PM
jyd83
Milwaukee Eight (M8)
30
Oct 31, 2023 06:07 PM
Evo-Wes
Mar 19, 2023 04:15 PM
Sartaj7
2018+ Softail Models
May 10, 2022 09:01 AM
x2lee
Exhaust System Topics
May 5, 2007 10:29 PM
