smoke
Old Aug 28, 2014 | 01:48 PM
landmark's Avatar
landmark
Stage III
Default smoke
my 2013 Road Glide 103 has recently started blowingwhite or blue ish smoke from the exhaust primarily from the left side you can see it in the mirrors when taking off ...it appears to only happen at relatively high rpm upon take off. there is also a black sooty residue around the end of my pipes which is not been there before. I have a stage 1 kit with Vance and Hines true duals and Screamin Eagle heavy breather these are the only engine modifications. I have also noticed a slight rattle or knocking at times not necessarily a ping more like a lifter. the bank is still under warranty but I'm concerned I can't get it into my shop until next week thoughts?
Old Aug 28, 2014 | 03:04 PM
baloot-boy's Avatar
baloot-boy
Blue smoke = burning oil. Do you have a tuner or update with your true duals and SE breather? Maybe you are running too rich or too hot from your mods?
Old Aug 28, 2014 | 05:36 PM
djl's Avatar
djl
If you have not installed a fuel management system and tuned the bike, it is running dangerously lean. Get a tuner and get the bike tuned.
Old Aug 28, 2014 | 05:53 PM
qtrracer's Avatar
qtrracer
Did it start blowing smoke on its own or after the heavy breather was installed? Are u certain the stock breather bolts were re-used? Other than that.........its under warranty so let them sort it out.
landmark
Engine Mechanical Topics
Aug 28, 2014 01:16 PM
landmark
Aug 28, 2014 01:15 PM
blackeg84
Mar 2, 2014 08:58 PM
bpshaw2006
Sep 24, 2012 11:04 AM
EVGHOG
Exhaust System Topics
18
Apr 12, 2009 12:55 AM
