Rocker oil leak question
So I tore down the cylinders to reseal the top end and have figured out that the rocker gaskets are very picky about how they are installed as I've already had to redo the front.
I've noticed that I had an intermittent spray of oil off to the side of the Rocker on the ground which will be fixed with new gaskets but more importantly I've noticed drops of oil on top of the transmission cover. Would this be because my Rocker gaskets were trashed due to my crappy install or has the gasket between the Rocker and Head failed? It's hard for me to tell, the gasket in the left hand side of the Rocker was proud and I could see it but this leak is tough to tell where exactly it's coming from.
Before you put new gaskets in, check the individual rocker box covers for warpage. Most common is the center one to warp. Place each one on a sheet of plate glass (or other known flat surface) and see if they wobble. It doesn't take much for them to leak, and no matter how many times you re-gasket them: They'll leak (long painful story).
Received 4,317 Likes
The EVO oil system 'collects' a lot of oil in the rockerboxes at highway speeds. Take your bike out on the interstate, or somewhere that you can run at 65+ mph for 20-30 minutes. Any leaks will show up.
