electrical issues
Old 10-18-2018, 09:52 AM
Guillotdl's Avatar
Guillotdl
Guillotdl is offline
Stage I
Default electrical issues
Hello all...
I have a 89fxr, the problem I am having is when I run with the lights on it pops, sputters, coughs an tires to die... when lights are off no issues... any ideas? I have replaced battery, cables, plugs, and headlight. Could it be the coil? If it is what should I be running 3ohm or 5ohm.. motor is mostly stock... thank you in advance
Old 10-18-2018, 10:12 AM
bagga's Avatar
bagga
bagga is offline
did you change out all the circuit breakers? i would start there if you already changed the other things.
Old 10-18-2018, 10:16 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,707 Likes on 1,343 Posts
Go through the charging system sticky.
Old 10-18-2018, 08:27 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
under the bike in the center is a ground strap - its bolted to the bottom inner primary and the frames cross plate - it comes loose and will drive you nuts trying to find whats happening - the bike looses its ground
FXR and FL machines in that era first place we go
Old 10-19-2018, 12:00 PM
86glider's Avatar
86glider
86glider is offline
Fwiw, when I changed out my spots and headlite to LED the voltage went up and ignition seemed to respond so much better.
Old 10-19-2018, 01:37 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Wink
The LEDs reduced the load on the charging system, which gave you that bonus. It's possible there is a lot of resistance built up at connectors and grounds, so you could consider doing some 'house-keeping' by disconnecting your grounds and connectors and cleaning then using dialectric grease prior to reassembly.
Old 10-20-2018, 02:28 PM
86glider's Avatar
86glider
86glider is offline
Absolutely,Sir .I also ditched some of the block connectors that imo will never be cycled ,and made solid connections which helped with intermittent lighting problems.
Old 10-20-2018, 03:49 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 7,004 Likes on 2,817 Posts
How's your battery and regulator?
rqndydodie69
Shovelhead
08-14-2018 05:05 PM
Stroked sportster
08-24-2016 07:03 PM
SoALposer
Electrical/Lighting/Alarm
01-25-2016 06:27 AM
Krazyndn
04-06-2014 05:55 PM
Revupar
04-27-2009 06:42 AM
Quick Reply: electrical issues
