FXR primary and tranny?
RE: FXR primary and tranny?
ORIGINAL: MercRider
Does the FXR primary and tranny share the same oil? And how do I check and change them?
The primary drain plug is located at the bottom of your outter primary cover.You'll need an allen wrench to take it out.Once drained plug back in,& derby cover off.Have the bike upright & fill with crankcase oil.Just fill it to the bottom opening of your derby cover & your good.
Tranny drain plug is located under your bike,,,,,,I think it's a 3/4 bolt,,,could be larger.After draining & putting plug back in.Again bike needs to be up right.Tranny filler cap is located just behind your rear brake pedal on your tranny cover.remove & fill with Belray Gear Saver SAE 80W90.DO NOT OVER FILL!!!!!!!!!About 1 pint should do it.
I would recommend buying the service manual,,,,,,comes in quite handy.
ORIGINAL: 87lowrider
ORIGINAL: MercRider
Thing is I dont know if a stock FXR manual would be helpful, becuz my FXR was build with diff S&S and other after market parts. I'm new to this V-twin scene. So if it seems that my question may sound stupid, its just becuz I'm just not quite familiar with these yet..
evosteveo (10-20-2021)
If it's still an HD motor regardless of the aftermarket parts,,,,,the specs should not change when it comes to fluilds.
ORIGINAL: MercRider
NMDave
15
02-21-2008 09:23 PM
