What's the Advantage to an Open Belt Primary?
The advantage is u will have the enjoyment of replacing the belt everytime a rock or pebble kicks up into it, also u get to finally use the expensive medical insurance u pay for when ur sock/pants catch in it for the first time. U will be begging for the chain. Just my experiance.
Biggie
HAMC
Biggie
HAMC
I promise, I am not trying to be argumentative, but the ONLY reason I don't have a belt drive on my Evo is because until Jireh released their new belt drive last month, aftermarket belt drives were close to two thousand dollars for an Evo setup. Thats hyway robbery, and I won't pay half the value of my entire motorcycle for an accessory. Now that they are in the 700's, I'll be putting one on much sooner than I ever thought.
_______________________________
pancho1952@hotmail.com (11-06-2021)
Right Bikerlaw, just like the final belt drive they are practically bullet proof unless you get oil on them. I've heard of teeth missing, holes, frayed, etc. on the final belt drives and thousands of more miles put on them.
As far as the oil for the stator goes; all the oil does on the stock primary drive is cool the clutch. It is not even necessary to oil that primary chain or the stator for that matter.
Before there were open belt drives we ran open primaries (back in the 1970s) with just the chain whipping around so I see open belts as 1000 times safer. An added plus to open chain primaries was if a cop pulled you over and you kept the bike running (at least until the cop said, "Shut it off,") the chain drip oiler and spinning chain would spray oil all over the cuffs of his pants, LOL!
The 3-inch belts are pretty tough. I know a guy that's had a hole in his belt big enough to get your pinky through and he's been riding a couple years like that. In a way I think most of you guys have it backwards. The belt goes on the front and the chain goes in the back, LOL!
1 Post
I've broken 3 or 4 1-1/2" belts on my 79 shovel. (Enclosed system) My friend Brian stripped the teeth off of his 3" open belt and it just spun and wouldn't drive the bike a few years back on a ride. My neighbor got his pants caught in his open belt drive primary and it sucked his leg down and back so hard and fast he broke his ankle.
We've had some pretty close calls in the shop with rags and fingers and such with open primaries.
But then, motorcycles are inherently dangerous. **** can happen. Personally I now run enclosed chains as they require so much less maintenance.
I love belt drives. And yes they can easily fail. IF YOU INSTALL THEM WRONG. Most people do not align the pulleys properly. This can lead to quick failure. I have seen BDL belts with a hole in the middle from a rock and the guy ran the damn thing forever after it. They just don't break that easy unless you don't know how to install them. I have an enclosed BDL on my 97 and have the inspection and derby covers off for venting. I love it. Cost me about 450 bucks after my factory clutch hub took a crap. That fixed my clutch, leaky stator plug and leaky primary. My previous evo had a 3 inch open BDL. It was rock solid.
shortride
04-29-2010 01:03 PM
