Remove paint from engine
Old Dec 12, 2014 | 08:14 PM
ronks2's Avatar
ronks2
Default Remove paint from engine
Have a 93 sporty that previous owner painted the engine black. Appears to be more than a few coats on the engine. Some paint had fallen off so I took the heat gun and removed a little more to expose the aluminum on the cam cover and it looked nice. Not sure if it left the factory naked aluminum or with a coat of paint on the side covers.
What products are out there that would remove the paint and be kind to the aluminum?
Thanks in advance.
Ron
Old Dec 12, 2014 | 09:56 PM
Tee&Vee's Avatar
Tee&Vee
If you're gonna polish the aluminum or even go for a mill finish then you'll be flapping then buffing, so.... I would just go ahead and do your damndest then polish away. If it is chrome underneath and you wanna keep it then disregard.
Old Dec 13, 2014 | 05:14 AM
grbrown's Avatar
grbrown
When new it's polished covers, if not chromed, will have been clear coated. It doesn't take all that long for the coating to start bubbling and the covers lose their appearance, which is probably why a PO painted the engine.
Old Dec 13, 2014 | 12:22 PM
monkeyboy22's Avatar
monkeyboy22
I've used aircraft stripper with great success. Takes the paint off and doesn't affect the base metal. It's available at most auto parts and hardware stores and is made by several different manufacturers. Available in aerosol or liquid. Then the buffing begins.
Old Dec 13, 2014 | 02:39 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Go to the local home improvement center or hardware store and get a pint of paint remover/stripper. Brush it on, let it stand for a while and hit it with a hose.
Use scotch brite pad to get the stubborn spots.
This is the same chemical that is sold in aerosol cans as gasket remover (at a much higher price).
The stuff is nasty, wear proper gloves and eye protection.
http://www.kleanstrip.com/product/premium-stripper
Old Dec 13, 2014 | 09:04 PM
ronks2's Avatar
ronks2
Default Thanks for the ideas
The covers appear to be polished and clear coated not chromed so both these products would probably work well for me.
Thanks for the suggestions.
Ron
Harleyyac
Mar 22, 2019 04:54 AM
nkfd13
May 1, 2013 08:45 AM
ihb75
Jun 19, 2012 03:12 PM
06 roadster
Aug 30, 2009 08:32 PM
BB
EVO
Aug 6, 2008 11:49 PM
