Retro fitting ABS braking system.
Howard Messner is a suspension guru who uses Ohlins components to custom build shocks tailored to Harleys and each individual customer. He also builds Ohlins cartridges for front forks and makes kits to adapt earlier bikes to the latest 49mm Harley forks. He does his suspension development using telemetry to record and compare real life performance of his products, as he develops them. And YES Harleys ride far better on top shelf suspension!
It sounds more like a suspension problem than a brake problem...
If the wheel isn't on the ground, the ABS will not know what to do.
An experienced, skilled, disciplined rider on a properly set up machine will stop faster than ABS every time.
I'd say the Ohlins is one of the best investments I've made on my bagger,
ride and handling, and I hardly ever scrape boards anymore, evidently the stock shocks were just staying compressed down in corners.
Stock suspension on Harley's has always been horrible, way too soft for the weight of the bike.
What kind of tired are you running? Maybe a softer rubber compound is what you need.
Also six piston calipers and a larger diameter rotor will allow you to stop the bike quicker and more effectively before reaching the lock up point.
If you want to get crazy, rotors that are the edge of the wheel, which is to say they are nearly the same diameter of the wheel will get the job done but aren't the prettiest things to look at.
