Fork Assembly Question
Old Feb 13, 2015 | 09:21 AM
johnod's Avatar
johnod
Default Fork Assembly Question
Is there some secret to compressing the spring so you can screw the cap back on?
So far I'm not having any luck.
Old Feb 13, 2015 | 09:28 AM
Beemervet's Avatar
Beemervet
Do you have the front wheel off of the ground? Did you change the length of the preload spacer? It can be a bitch sometimes.
Old Feb 13, 2015 | 09:56 AM
grbrown's Avatar
grbrown
Talking
If Amy can dismantle and rebuild dresser forks then any of us ought to be able to! (Scroll down for videos!)
Old Feb 13, 2015 | 10:35 AM
tmanbuckhunter's Avatar
tmanbuckhunter
When we put spacers in my tubes, we had to put a ratchet strap over the ratchet to hold everything down, and it still took 3 guys putting pressure on it to get the job done. It was a major PITA.
Old Feb 13, 2015 | 10:43 AM
johnod's Avatar
johnod
I checked that video previously, Amy kinda skips over that part.
Yes I've put in intiminators and racetech springs and spacers, so it is different.
The legs are out of the trees.
Old Feb 13, 2015 | 10:53 AM
Architect's Avatar
Architect
I find using an air ratchet makes quick work of the job. You can push down as needed and let the ratchet spin the cap until it catches.
If that is not available, two man job of pushing down and turning the ratchet.
Depending what you are using to hold onto the tubes, it might be easier to put them back on the bike first so they are not moving around on you.
Old Feb 13, 2015 | 01:35 PM
Yankee Dog's Avatar
Yankee Dog
I recently went through this, see this post:
https://www.hdforums.com/forum/evo-c...caps-rock.html
I used a wood working clamp (linked a pic in the above post) and also protected everything with duct tape. I managed to get it all together without removing handle bars. Hopefully it helps. YD
Old Feb 13, 2015 | 04:33 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I bought a palm ratchet for the next time I had to help someone on their bike.
3/8" Drive Mechanic's Palm Ratchet Tair0782 - Drive Sockets - Amazon.com 3/8" Drive Mechanic's Palm Ratchet Tair0782 - Drive Sockets - Amazon.com
Old Feb 13, 2015 | 04:52 PM
johnod's Avatar
johnod
Well not having any of those tools, I used some clamps, wooden V blocks, a gear clamp with some rubber to line it, and a hydraulic press. Worked pretty good.
Old Feb 13, 2015 | 05:00 PM
texashillcountry
Dirt don't hurt
You don't by any chance have a picture of what you rigged up to do this do you?
