Fork Assembly Question
Old Feb 13, 2015 | 05:12 PM
Tom84FXST's Avatar
Tom84FXST
Got tired of fighting them, so I built this
Old Feb 13, 2015 | 05:17 PM
johnod's Avatar
johnod
Originally Posted by texashillcountry
You don't by any chance have a picture of what you rigged up to do this do you?
No. I'll try to explain it tho, pretty simple really.
I extended the fork, slipped the rubber lined gear clamp down the tube to the top of the lower leg, and tightened it so the fork won't collapse.
Took the fork leg, and slipped it between the cross bars on the press.
A wooden block supports the bottom of the fork to the correct height.
Two wooden V blocks, (notched 2x4s) were then clamped to the upper fork tube, resting on the top of the cross bars of the press.
After carefully lining fork leg up with the press's ram, I clamped the V blocks to the cross bars of the press, now it's not going to slide or wiggle.
Position the fork cap in place on top of the spring spacer.
Then carefully press cap down so it enters top of fork leg, till you can feel it hit the threads.
Then tighten it , making sure it doesn't slip from under the ram,
That's it.
Hope that was clear.
Old Feb 13, 2015 | 05:38 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That's it.
Sounds complicated but I'm glad you got it back together.
Old Feb 13, 2015 | 05:41 PM
johnod's Avatar
johnod
Sometimes you have to do things in a more complicated way when you're working by yourself.
Old Feb 13, 2015 | 07:19 PM
texashillcountry
Dirt don't hurt
Yeah I keep running into jobs that would be much easier if I had 3 hands!!
JekyllnHyde
Jun 19, 2019 02:26 PM
woody1978
Jul 10, 2017 12:07 PM
Beach Bagger
Aug 19, 2013 08:10 PM
milesvdustin
Apr 10, 2013 07:23 PM
Edward Brown
Shovelhead
May 7, 2012 12:24 PM
