Basket case
Old May 6, 2015 | 08:37 PM
  #111
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Beemervet
Probably rear master.
There is a hose connecting the rear reserve to the mastercylinder.
I suspect the hose.
Old May 6, 2015 | 09:42 PM
  #112
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by texashillcountry
While waiting on parts I decided to put fresh brake fluid in the brake lines.
I'm real glad I did!!!
The rear reservoir was dead empty and the front one was a funny yellow color.
I didn't know DOT 5 turned yellow!!!
It does when moisture gets into it.......
Old May 6, 2015 | 09:47 PM
  #113
texashillcountry
Dirt don't hurt
I thought DOT 5 didn't absorb water.
Old May 6, 2015 | 09:54 PM
  #114
misfitJason's Avatar
misfitJason
Originally Posted by HGM
Its true guys, we're among the worst too.. We dont want junk parts, we want good quality and in many cases for our EVO, that means used.. When we need new, we get online and shop for the best deal. Well, the indy's are buying from the same suppliers as the online dealers, but they dont buy the volume that an online dealer does. In order to make a living, they have to price it even higher.. It's a vicious cycle, but we are a part of the problem.. There is plenty of money out there, everyone is spending it, but the locals are starving and closing because of the internet.. Hell, you can shop around and find anything have it in your hands within a couple of days, all without leaving your house, burning time and gas.. Its really no different than local hardware stores driven out of biz by the big box stores that have everything.. Modern age baby..........
What's these internets that you speak of?
Old May 6, 2015 | 09:58 PM
  #115
misfitJason
A friend of mine once asked me how his brake fluid got low after a year or two being that it's a closed system. And I thought about it for awhile. What I came up with was evaporation. Think about it. You fill it up and seal it. The fluid itself over time gets heated up and cools down which by itself will cause evaporation. The the piston is moving in and out of the caliper bore being pushed by the fluid itself and lubricated by the fluid. Everytime the piston comes out so does a minuscule amount of fluid. But over time that fluid equates to a good amount and that fluid goes to the air by way of evaporation.
Old May 7, 2015 | 06:04 AM
  #116
98hotrodfatboy
I didn't think it did either till I opened my rear reservoir ......
Old May 7, 2015 | 08:58 AM
  #117
texashillcountry
Dirt don't hurt
What vehicle did your friend have this happen to?
Old May 7, 2015 | 08:29 PM
  #118
okjoe's Avatar
okjoe
6th Gear
CLEAN it OFF! NEVER use any sealer on oil pump gaskets other than a thick grease or beeswax. Anything else WILL plug things up and you DO NOT want that! Retired H.D. Certified Tech.
Old May 7, 2015 | 08:52 PM
  #119
texashillcountry
Dirt don't hurt
Thanks
You are a little late but thanks anyway.
Old May 8, 2015 | 09:21 AM
  #120
texashillcountry
Dirt don't hurt
Almost finished.
Just a few other odds and ends.
