Options 12v power
Old Aug 27, 2016 | 07:35 AM
Dazzauk's Avatar
Dazzauk
Default Options 12v power
Hey all what would my options be for installing 12v power socket or a sub socket? For sat nav phone etc.
I've seen Harley do a horn mounted one part 69201136 But can't work out if it will fit my glide?
Also headlight bulb upgrades or tips to get better beam. ? Not sure if it's my bulb that's running or inside reflector or glass is dirty.
Cheers
Old Aug 27, 2016 | 07:45 AM
Prot's Avatar
Prot
Replace your headlight with Truck Lite LED headlight. Best place to order them from is Drive Train America. I out the three piece kit on my Heritage. Truck Lite is a lot cheaper than JW Speaker and works great.
Easiest way to get a USB or cigarette lighter type of socket is to get one that plugs into the SAE plug that is on the end of a battery charger pigtail
Old Aug 27, 2016 | 07:52 AM
Dazzauk's Avatar
Dazzauk
Would you have a link for anything power socket wise? The only battery charger pigtail I have is a aftermarket one
Old Aug 27, 2016 | 08:27 AM
Prot's Avatar
Prot
Nothing wrong with aftermarket but if you want HD then here are a couple of things.
http://www.harley-davidson.com/webap...tentryId=13814
Old Aug 27, 2016 | 08:45 AM
Prot's Avatar
Prot
I realized your bike takes a 5 3/4" headlight. Truck Lite does not make that size.
Here is a decent deal on one made by JW Speaker.
https://www.ebay.com/itm/121978798727
Old Aug 27, 2016 | 09:48 AM
Dazzauk's Avatar
Dazzauk
Cheers bro.
Ok... So I think I've sorted a nice usb power socket with sae plug.
Next question is if I were to run a usb lead from either iPhone or sat nav to let's say middle of the bike somewhere what's the best route????
I've looked at some gps units but it looks like a lot of them are hard wired and I would want to remove it quickly.
Old Aug 27, 2016 | 02:50 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
For a power outlet Drag Specialties has several.
The cheapest one is a $20 cigarette lighter which is the one I use.
It mounts on the handlebars and is easy to install but you do have to extend the wires because the ones they send with it are very short.
For gps get a ram mount and put your phone in it (assuming you have a smartphone).
Old Aug 27, 2016 | 04:49 PM
Owtlaw's Avatar
Owtlaw
I use this one mounted on the bars.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old Aug 27, 2016 | 06:53 PM
Dazzauk's Avatar
Dazzauk
Thanks texashill country.
I'll look into both of these. Hopefully can get in the uk easy enough.
Old Aug 27, 2016 | 07:11 PM
Dazzauk's Avatar
Dazzauk
Ok so I've ordered this https://www.amazon.co.uk/Terminal-Ha..._1472307624513
Now I'm struggling to find what kind of case to use on my iPhone 6 Plus. The ram mounts don't look like hey would hold the phone securely enough to ride with ?
