Rocker noise
Old Sep 11, 2016 | 01:53 AM
Big Panda's Avatar
Big Panda
Default Rocker noise
Alright, I have ready many a thread about rocker/lifter/pushrod noise on these Evos. However I think I am just as confused as I was to being with. I noticed a "tick" on my '91 FLHS (7,000 miles) that is in time with the cylinder. It is most noticeable at idle but is heard all throughout the rev range and the noise speeds up and slows down with engine revs directly. It doesn't sound like metal hitting another solid piece of metal but sounds more like metal brushing another piece of metal, almost like a small exhaust leak. This is my first Harley and I know they tend to be "noisy" bikes and I have no problem with that I just want to make sure that I'm not ignoring a sound that may lead to a potential problem. The sound is definitely coming from the front piston rocker box area. That's as narrowed down as I could get it. I've read a lot about pushrods and lifters making a noise similar to what I am hearing. I just did a fluid change on the bike, all three fluids and the sound didn't change. I have yet to check the screen that I have read about people cleaning (because I don't know where it is or how to access it!). Really trying to avoid taking it to a mechanic as I used pretty much all my funds to buy the bike. I am fairly handy and a quick learner and would love to do as much work on the bike myself as possible. I am 99% sure everything on the bike is bone stock. Any help would be great.
Old Sep 11, 2016 | 02:32 AM
Son of PMS's Avatar
Son of PMS
http://www.youtube.com/watch?v=47ljGG0XMa0&sns=em
Old Sep 11, 2016 | 09:17 AM
glidein wide's Avatar
glidein wide
An exhaust leak can sound just like a tick, so double check that, is the sound the same on a cold start also or quieter ? My finger in pic is pointing to the screw to access the screen, there is a spring there with it to hold it down. Inspect what you find in the screen for your own personal knowledge then clean with brake cleaner and reinstall. Your screw will look a little different from mine because mine is aftermarket for easier removal.
Old Sep 11, 2016 | 09:18 AM
glidein wide
Old Sep 11, 2016 | 10:22 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
A good running EVO sounds like a pissed off sewing machine.
Does your bike sound like that?
If yes don't worry about it.
If no then try and locate the source of the tick you are hearing and let us know what you find.
Old Sep 11, 2016 | 12:31 PM
Big Panda's Avatar
Big Panda
The sound seems to be the same cold or hot. If anything it gets a touch louder when it's hot but that may just be my imagination.
That is a pretty precise description of what it sounds like which is why I wanted to come here and ask since it seems it may just be how these bikes sound.
Ill check the screen today and see how it looks.
Old Sep 11, 2016 | 02:13 PM
texashillcountry
Dirt don't hurt
I bet you're probably fine then.
Old Sep 14, 2016 | 01:52 PM
engr146's Avatar
engr146
I use lucus 20/50 and my engine and valve train quited rite down,I thought something was wrong with my bike when I first bought it 4 years ago.I won't use anything else.
Old Oct 9, 2016 | 08:49 AM
glidein wide
I have a question... after installing the brass tube(rocker lockers) ,are they designed to be permanent until the shaft needs to be removed ? I assume you need to press them out and basically ruin them if you should need to remove the shaft, and reinstall new set. Would I be correct ???
Old Oct 10, 2016 | 01:38 PM
Alienwulf's Avatar
Alienwulf
I have removed them, if your careful, I just tapped them with the bolt and they slid right out and can be reused.
