Fxrs-sp forks leaking/air leaking
Old 06-13-2017, 08:09 PM
lmz5150's Avatar
lmz5150
lmz5150 is offline
Default Fxrs-sp forks leaking/air leaking
I've got an issue with my air assist forks.
first, they seem to lose air pressure over a couple days. Then the forks are super soft and have a lot of dive.
Next...I have a fluid leak back behind the headlight. I assume it's from the distribution block for the air assist.
Is this set up serviceable?
I can find fork seals, rebuild kits etc, but I'm not sure of the air assist stuff is separate.
I don't have wet fork legs, like a wiper or seal is leaking. Just the air stuff. When the system is pressurized it works great. But otherwise...very..flaccid
Old 06-14-2017, 06:49 AM
89FL's Avatar
89FL
89FL is offline
Old 06-14-2017, 01:44 PM
lmz5150's Avatar
lmz5150
lmz5150 is offline
Thanks for the link to the jp part.
i might have gotten lucky tho. I had time this morning to pull the headlight etc off the the bike, and it looked like my leak was at the hose connection to the solenoid. The clamp was loose and the hose would turn and was easy to pull off. Replaced that pinch clamp with a gear type, can't see it behind the light anyway. Maybe that will take care of things.
rsking45
03-19-2014 06:42 AM
Devon
EVO
07-02-2013 09:18 PM
mdanehart
EVO
04-04-2013 04:28 PM
TexasBowhunter
11
02-20-2012 07:23 AM
mike56
07-16-2007 02:07 PM
Quick Reply: Fxrs-sp forks leaking/air leaking
