Dead Gauges - 1990 Electra Glide
Old Oct 17, 2017 | 05:43 PM
  #41
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by 0maha
I'm going to dig through the wiring diagrams tonight, but off the top of my head, I don't see how the module is involved in the brake lights. Am I wrong on that?
Ooohhh...this might be something.
I didn't think this was related (and therefore didn't mention it), but the bike has gotten a bit sketchy about starting over the last few months. The symptoms are that once in a while (say, every five starts) it will hesitate for a half a second before turning over. Maybe one time in ten, it won't turn over at all unless I release the starter button. It always fires right up on the second hit.
Both of those seem to be worse when it's good and hot.
Think that could be related?
IIRC your starter relay utilizes the center pin to kill the power to the rest of the bike when starting.
A new starter relay is like $6.
Old Oct 17, 2017 | 06:26 PM
  #42
0maha's Avatar
0maha
I think we're on to it.
If I disconnect the relay, I get exactly the same symptoms as when the dash goes out.
Went ahead and cleaned the contacts really well. Reconnected the relay and went for a short test ride.
So far, so good. I'll give it a day or two to see if the problem returns (in which case I'll replace the relay), but at the moment it looks good to go.
Now, really, nothing else can go wrong!!!
Old Oct 17, 2017 | 07:35 PM
  #43
texashillcountry
Dirt don't hurt
Old Oct 17, 2017 | 08:16 PM
  #44
WP50's Avatar
WP50
Yes. Just discovered that the brake lights and turn signals are non-op when this happens
ThC and I were on the phone shooting the bull earlier. Playing with my bike on accessory, the turn signals worked , the back light on the speedo was on (others off) and the hazard flashers would work. No brake lights tho.
And the fuel and volt meter didn't register anything. (no needle movement)
Just more stuff to think about
WP
Old Oct 17, 2017 | 08:18 PM
  #45
WP50's Avatar
WP50
Originally Posted by Dr.Hess
I seem to recall there is also a ground that runs from inside the fairing on the triple tree to the frame. Check that one too.
That's the ground connection that was messing with mine once upon a time.
WP
Old Jun 6, 2023 | 02:46 PM
  #46
Ray on the drums's Avatar
Ray on the drums
Old thread, I know and I don't care. Not starting a new thread for a couple questions. The housing that holds this row of breakers behind the headlight, I will find a ground wire coming out of what the back side of it? While I'm there I want to change all them breakers, are they all 20 amp? I did the main breaker down near the battery with a 50 amp. Also have a '90 Electra Glide. Plus I'll be checking and looking for the ground Dr. Hess mentioned.. Thanks!
Old Jun 6, 2023 | 08:26 PM
  #47
WP50's Avatar
WP50
Ray go ahead and start a new thread. You'll better of in the long run.
Reference this thread if it was of some help
good luck WP
Old Jun 7, 2023 | 11:57 AM
  #48
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Start a new thread, too many will be answering the original post, just making it confusing.
eglideic
Touring Parts
Sep 14, 2017 06:02 PM
toketee
Sep 21, 2012 08:35 PM
fathertime
EVO
Nov 10, 2010 11:33 AM
Rudy64
May 29, 2010 07:07 AM
krashcars
May 9, 2009 02:57 PM
