Needing some help
Old May 7, 2018 | 09:06 PM
mikeawin's Avatar
mikeawin
6th Gear
Default Needing some help
I have an 88 electra guide classic. The issue I have is rolling into the throttle it almost acts like it is going to stall out. Unless I let off the throttle then try to roll into it. It is idling at about 900 rpm once it warms up. I recently cleaned and replaced all gaskets. The jets have been replaced as well. Didn't notice issue prior to rebuild. Have done some looking at videos but have not found a solution yet and want to get some riding done. Any and all assistance is greatly appreciated
Old May 8, 2018 | 06:21 AM
flhchaz's Avatar
flhchaz
Can you tell us what carb is on it? Is it stock?
Old May 8, 2018 | 06:27 PM
mikeawin's Avatar
mikeawin
6th Gear
i have an older model keihin carb on the bike. I
not 100% sure if this one came with the bike. But it is a possibility. Thanks
Old May 8, 2018 | 07:05 PM
Beemervet's Avatar
Beemervet
Your best option is to junk that carby and install the CV.
(Here comes THC........... S&S S&S S&S S&S!)
Old May 9, 2018 | 11:33 AM
GOGOBECK's Avatar
GOGOBECK
I believe the Keihn is a CV.
Old May 9, 2018 | 12:21 PM
rizzo's Avatar
rizzo
Anyone nearby with a Dyno? It should show you where the trouble spots are. Sometimes you can get a couple pulls and they might give you a recommendation. There's a guy near us that will and some that won't.
Old May 9, 2018 | 12:30 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Not all Keihin carbs are CV...
If the carb is original, it is not a CV. Harley did not put CV carbs on big twins until `90.
Old May 10, 2018 | 09:52 AM
mikeawin's Avatar
mikeawin
6th Gear
I am sure that it is not a CV carb. It is 1 or 2 gen Keihin carb
Old May 10, 2018 | 10:14 AM
Beemervet's Avatar
Beemervet
OK, I will rephrase: Your best option is to junk that first version Keihin carby and install the later version Keihin CV.
Old May 10, 2018 | 10:15 AM
Dr.Hess's Avatar
Dr.Hess
I'm going with main jet blocked. That carb doesn't even make a good door stop.S&S.
