Taller Front Pulley Gearing-1996 HD EVO 5 Speed??
Instead of buying a custom 6-speed Tranny i wish to just cheaply Buy a 2 belt Teeth Bigger OD Front Pully.
I think I know a Cheap remedy to your gearing issues/Thread. (i als replied the the 6 speed transmission old post today.
My-The stock 1996 FXSTC softail EVO 5 speed Transmissions are better/stronger than the HD & Aftmkt 6 speed transmissions.
Why should I buy a Baker $5k-$5000 6-speed when i can gear up my front Pully by 2 teeth and get a better MPG-Cruising range for $200 or so?????
1996 FXSTC 1340cc HD Softail Front Pully Gear-Up Taller by 2 Teeth??
I love my 5-Speed, so i want to keep the 5-speed and i just want to replace my front stock HD Pully Only by an aftermarket 2 Teeth bigger pully, and wonder if anybody here has done this?? I am worried the Belt will rub against the metal beltguards with the bigger-2 teeth OD aftmkt front Pully??
Note: I heard I can buy a slightly longer Belt!!! to help with my project.
I really Dont want to remove my metal HD 2 Beltguards to do this proj as i Lov them.
????Does anybody know if the Stock OEM metal Belt-Guards will Rub on the Belt with this 2-Teeth front aftmkt Pully Modification-Taller overall Gearing Upgrade?????????
Has anybody here of Forum done this EVO front Pully 2 Teeth bigger Mod without rubber-Belt/metal-Beltguards rubbing-conflict problems?????
Thx Mch,
scooterScotty
Thx Mch,
scooterScotty
Yes you can buy a larger pulley, for which you will need a 2 tooth longer belt. The pulley is only slightly larger in diameter than the stock one and I have never heard of anyone having problems doing this, your guards should be fine. You will be following in the footsteps of many others when doing this! You will need to dismantle the entire primary and swingarm, to change belts. In my experience your stock belt won't work. If you don't have one, now is the time to buy the genuine FSM.
We went the other way - went one fewer tooth on the front sprocket. The trike is pretty heavy. It gets off the line better now.
"third link" - had to look that one up. I've never had the problems it's trying to solve.
THX!!! So Mch Mr. Brown/king/Ford
Dr. Brown is a HVY DUTY HD Guru-Mech. & HD Rider 4 Sho!!!
U Hog Guys Rule & Rock HD!!!!
Amazing!!!
Kool!!!
i will reply to posts on FSM Belts?? and Swingarm Upgrading??
Where do I buy the FSM (2 teeth xtra-longer)rubber final drive Belt??
Are FSM 2-teeth longer belts still Made?? and Available??
Where can I get Info?? What Co. Makes the Swingarm upgrade kit?? What does the 3rd link do to the Swingarm?? My 96 FXSTC Softail 1340cc does have a swingarm, but never heard of any upgrade??
btw, I never heard the Swingarm has to come of to Change the Belt??
btw, Approximately, How long does a not abused HD Evo Belt last in Years?? and Miles??
Wow!!! i knew U Rockd, but dint expect such Awesome & obscure Hog Info so fast etc!!!
You HOG Riders RULE!!!
Thx,
HOGLover,
scooterScotty
Trikes Rule!!! Esp old ones in 70's movies w/ Toilet on back!!!
GNARLY Trike!!!
U shld have Pic of Trike to go along w your Kool Hogs etc.
Thx,
ss
Amazing!!!
Kool!!!
Thx,
HOGLover,
scooterScotty
GNARLY Trike!!!
Thx,
ss
There are many options for swing arm rebuilds and I am not here to tell what is best.
I do mine every 5 years as that is when the level starts to go south.
Last time I used HD stuff, next round it will be aftermarket electrometric stuff.
I would not convert to bones on bones steel brass bushings as it would ruin the less vibration concept i would think
THX THX THX THX Dr. GBrown aka HOGDOCTOR!!!
Are FSM 2-teeth longer FSM belts still Made?? and Available 4 sale??
Who/What Company sells this Swingarm (Add 3rd Link) Upgrade Kit??
btw, I never heard the Swingarm has to come off bike to Change the Belt?, but yes good time to take it OFF if I do the 3rd Link Upgrade??
btw, i had Race-tach put the Gold emulator Valve in the front Forks (works Grt!!!) & in future i will buy Race-Tech's rear Softail Shock (w/adjustments for 1 up riding),
but i never heard the Solid HD swingarm could be made any Better-Upgraded w/ 3rd link?? Unless u r just "pulling my leg"/Joking?? cuz Im not a HD techy like many of you Gurus LOL
Kooo!!!
I hope someone chimes in that Did this Without any Clearance/Belt-Beltguard Rubbing issues,
but I do believe you.
Thx,
HOGLover,
scooterScotty
Kooo!!!
Thx,
HOGLover,
scooterScotty
THX KING!!!
Where can I find Swingarm upgrade kits that do this??
Where do you get the Electrometric kit stuff??
I have never heard of Softail Swingarms needing anything, but i will ask my local HOGSHOP Guru.
Maybe your Hog swingarm is problematic to wear???
i was told BDL and Rivera primo may hav stuff.
What is the FSM final Drive rubber Belt GBrown mentioned??
FSM???
Thx
ss
FSM???
Thx
ss
