Has My Dyna Had The Cams Replaced?
So I'm new to Big Twins, only owned the Dyna since December. Other Harley's are Sportsters.
I was looking at the Low Rider the other day and notice the Push Rod tubes seem to be 2 piece. My Sportsters they are one piece. I ran across a Youtube video where they were doing a cam upgrade and instead of pulling the rocker boxes off they cut the push rods and tubes with a bolt cutter and put in adjustable push rods and a two piece tube.
I know the bike has a K&N air filter, jet kit, and pipes on it.
Just wondering if it has had cam work done on it too?
Received 14,559 Likes
If you are talking about push rods being 2 piece instead of the PR covers, then yes, you would have aftermarket PRs. You could easily pop off the PR covers to check.
If you have aftermarket PRs, you may have a cam upgrade, but not necessary. The only way to find out is to get in there. The other reason a cam cover is replaced is if the pick-up sensor needed replacing.
I'm betting you do have an aftermarket cam, because you have non-stock pipes and free flowing air filter.
I'm willing to bet that the bike already has a cam. Look at the chrome upgrades on that bike. Someone spent a little money putting that on, and probably would have put a cam in the bike with other upgrades. Again, the only real way to find out is open her up.
