front signal light problem
Old May 2, 2020 | 08:43 AM
evobo98's Avatar
evobo98
Stage I
Default front signal light problem
For the life of me , I can't get the LH running light to work. All signals work.
Old May 2, 2020 | 08:47 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Either bulb no good or break in power to that filament.
Old May 2, 2020 | 08:53 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
FWIW I had a problem with turn signals a while back and the problem turned out to be the Kuryakyn run/turn/stop module under the seat.
If you have anything like that remove it and see if your turn signals start working.
Old May 2, 2020 | 08:57 AM
grbrown's Avatar
grbrown
If your running lights are integral with the indicators and use twin filament bulbs, try a couple of things. Check the 'faulty' bulb closely, as one filament can break but leave the other one working OK. Failing that swap bulbs from one side to the other and see if the fault follows, or stays put. Obviously if it follows, then the bulb is faulty, if it stays put the fault lies in the wiring/grounds somewhere.
Old May 2, 2020 | 08:58 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Help us help you.
Model and year?
What have you checked so far?
Back to you...
gmorgens
Feb 8, 2016 05:36 PM
dkin01
Oct 6, 2009 05:14 PM
Jim Dawson
Jul 19, 2009 09:43 AM
endngrdspecies
Electrical/Lighting/Alarm
Nov 28, 2008 04:33 AM
jackietan
Sep 10, 2007 02:52 AM
