Early case, later flywheel
Old Jun 18, 2020 | 02:22 PM
daven9113's Avatar
daven9113
Default Early case, later flywheel
'88 case with '97 flywheel assembly. What do you guys do to get the cam cover to fit? 1) Turn down the pinion nut 2) cut pinion bushing a little deeper or Both. Any advice. Asking for a friend.
Old Jun 19, 2020 | 05:47 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Not sure it's gonna work. I believe the early covers oil ports are different than the later.. I suggest you call a local indy that is also a machine shop..
Old Jun 19, 2020 | 02:37 PM
daven9113's Avatar
daven9113
Thanks. I think all Evo pinion shafts are end oilers, and so are the cam covers. Early shovelheads had side oiler holes, I believe. Just wanted to see if anyone has put one together. Clearance of the pinion gear nut is the only issue I can foresee, but I'll do more research on it. Just looking at putting together a swapmeet special engine to learn and have some fun. Covid thing has stopped all local swapmeets, and I have no idea when they will pick up again.
Old Jul 16, 2020 | 05:57 PM
Dacew's Avatar
Dacew
6th Gear
Default Evo engine build
Just finished truing flywheels numbers look good. 001 at crank .003 at pinion race ...monted them in brand new s&s case took another raeding at pinion number was high .007 .....any ideas why
Old Jul 16, 2020 | 07:34 PM
Beemervet's Avatar
Beemervet
Go back to your own thread!
Old Jul 20, 2020 | 10:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You already have a thread started elsewhere on the forum.
Don`t barge in on someone else`s thread, it causes confusion, and it is rude.
ShovelheadSebak
Shovelhead
15
Jan 20, 2020 07:58 AM
jerryboy
Engine Mechanical Topics
Jul 16, 2019 06:16 PM
shankman
EVO
May 22, 2016 09:14 PM
shankman
EVO
May 15, 2016 06:36 AM
RidemyEVO
EVO
Feb 8, 2012 09:39 PM
