Inner Primary - Bolts
Old Aug 30, 2023 | 01:50 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Default Inner Primary - Bolts
97 WG: Did a small search and am trying to figure out where the large and small bolts go.
Attached picture below - 4 holes to the left and 3 to the right.
Old Aug 30, 2023 | 01:58 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Put the inner primary cover in place, push all the bolts into the holes but don`t thread them in yet.
They will all have the same space between the bolt head and the inner cover when they are in the right position.
Or use the parts manual:
Link to parts manual.
Old Aug 30, 2023 | 04:38 PM
Yankee Dog's Avatar
Yankee Dog
Heads up:
At least on my 94, one of those long bolts for on the trans is just a 1/4 or 1/2 inch shorter than the other. I wish I remembered what spot that one was located, but I think a dry fit based on Dan89FLSTC suggestion is a good idea. Also looking up the part numbers to each bolt then googling that part number is an even better idea. I would hate to see you put a bolt that is too long in a hole that is not machined to receive it. Thats when aluminum parts start to break.
Maybe your 97 does not have that one shorter bolt, but worth a look.
Old Aug 30, 2023 | 05:11 PM
t150vej's Avatar
t150vej
Short ones go in the front (engine). The long ones go into the transmission.
It had an aftermarket inner before, so it's possible some of the bolts you took out are incorrect so measure them.
4 - 5/16-18 x 1 1/2
3 - 5/16-18 x 3
Old Aug 31, 2023 | 10:59 AM
GREENOHAWK69
4 - 5/16-18 x 1 1/2
3 - 5/16-18 x 3
Thanks. That was my guess and I put them in that was without the inner primary on. I have a 95 Dyna inner primary now, so I'll test fit first before I start using caulk on the bolt threads.
Old Aug 31, 2023 | 11:25 AM
t150vej's Avatar
t150vej
YW.
With the '95 inner, the 2 front bolts (external) are 1 7/8" long. The part # is 4068A You'll never find that length in a typical hardware but 3" should work. The other 5 bolts are lengths I listed earlier.
Be sure to use a new o-ring on the engine no matter how good the old one looks. Ask texashillcountry how I (we) know.
Old Aug 31, 2023 | 01:56 PM
eighteight's Avatar
eighteight
^ I think he means 2" will work
Old Aug 31, 2023 | 02:08 PM
t150vej's Avatar
t150vej
Thanks 88. Yeah, I've been having senior moments lately and "you just can't find good help these days"
Old Aug 31, 2023 | 03:18 PM
98hotrodfatboy's Avatar
98hotrodfatboy
You can find 5/16"x 18 x 1 3/4 Socket cap screws.. Work and look excellent.. it's what I use .
https://www.fastenere.com/516-18-soc...QaAsA1EALw_wcB
I'll bet you can find them at a local hardware store..
Just wanted to update the only place I use a socket cap screws are on the two front inner primary to case bolts..
Old Aug 31, 2023 | 03:51 PM
Schex's Avatar
Schex
Don't forget to put a round of rtv sealer near the head of the bolts after you slide the tabs lock on.
rydahog
Aug 30, 2017 10:44 PM
N-Rico
Sep 12, 2015 06:11 AM
bipolarsporty
Sep 6, 2013 11:35 AM
billymons
May 31, 2009 10:52 PM
nosinjcted
35
Mar 9, 2009 08:32 AM
