Agm battery
Old Mar 15, 2026 | 04:40 PM
Goose_NC's Avatar
Goose_NC
I ran AGM batteries in my 1989 ElectraGlide. I did so with the stock electrics and the CycleElectrics upgrade system. No issues.
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by HarvHD
I'm pretty sure not all sealed maintenance free batteries ard AGM. Sealed maintenance free batteries were around before I ever heard of AGM's.
Yeah, and you had to pry the caps off to add water...
Old Mar 15, 2026 | 04:41 PM
Max Headflow's Avatar
Max Headflow
I don't think HD sold any gel cell batteries.
Old Mar 16, 2026 | 05:51 AM
eighteight's Avatar
eighteight
I believe you have a 22 amp charging system.. .
Recently pulled a working AGM from a 78 FL with stock charging system
It lasted 7 YEARS
Old Mar 16, 2026 | 08:53 AM
98hotrodfatboy's Avatar
98hotrodfatboy
[QUOTE=glidein wide;22237698]Back when I rebuilt the bike I increased charging system to a higher amp charging system I believe is 32 amps. Harley battery is sealed maintenance free,got5 years from the last one, this one not so strong, 330 cca new AGM looking at is 325cca...but yes everything will be checked and cleaned including the lollipop in the Solenoid.[/QUOTE
Then there shouldn't be any issues.. I really like the Interstate 320 cca.. I got 7 years out of my last one
https://canadabatterysystems.com/int...ies-fagyz20hl/
Old Mar 16, 2026 | 01:07 PM
t150vej's Avatar
t150vej
Originally Posted by glidein wide
I'll have to investigate the oem battery specs.
OE flooded battery was 165cca @20ah. Most all AGM will be about 320-340cca@22ah
Old Mar 16, 2026 | 09:49 PM
Schex's Avatar
Schex
I just had a 500cca Yausa bagger battery die, installed in early ‘19, 7 years is a good run.
Old Mar 17, 2026 | 06:41 AM
98hotrodfatboy
Yeah the fl's take the 30 series batteries.. you can get a lot higher ampere and cca rating than that of the 20 series..
Old Mar 17, 2026 | 06:51 AM
touchdown's Avatar
touchdown
can they catch on fire?
Old Mar 17, 2026 | 06:55 AM
eighteight's Avatar
eighteight
I believe you are confusing AGM with some Lithium variants
