97 road king no start
Hey all, I have a 97 road king and I fried something and not I cannot get it to start. So to preface, the battery died over the winter, I jumped the bike multiple times to start it over the winter. A couple days ago I replaced the battery, then removed to tank to change plug wires, and throttle cables and the petcock. Put it all back together and no start. I pulled a spark plug and I’m getting spark, albeit an orange tinted spark. I see gas spraying into the intake when I twist the throttle. FB groups seem to think I fried the regulator since I jumped it off with a jump pack so much, which I’m ok with I can chalk it up to a lesson learned and if that’s the case I learned a valuable lesson. Is this a symptom of a bad voltage regulator? Thanks in advance !
unfortunately I have already tried that and purchased 2 brand new batteries. It’s frustrating man, I’ve always been able to work on my own bikes but this is the first time I have ran into something that seems electrical. It’s not even my bike, it’s my dad’s and I’m just trying to get him back on the road before he starts his cancer treatments this summer. I gave him the keys to my softail for the time being but I would really like to get his road king going.
Use the choke full out and do not twist the throttle. It's real easy to flood them on a cold start/sitting long. I usually hook jumper cables to mine off the car. Just crank on it for no more than 15 seconds then let it cool 2 minutes, repeat.
I can tell you, starting one wit ha CV after it has sat for a while can be difficult, mine is. Regulator has nothing to do with starting (for now) If the ignition module dies, it's dead. A coil can get weak. With the tank having been off you may not have gotten the carb full if it's a vacuum petcock. Only takes 1/8" gas in the bottom to squirt.
Take the timing cover off, see if it's tan goo running out. And I assume you use resister wires.
I just looked at the timing cover and I don’t even have to take it off to see the tan goo. It coming out of the timing cover
And theres your problem.
