97 evo cam
Old Apr 20, 2008 | 04:03 PM
fripple's Avatar
fripple
Default 97 evo cam
what is the lift on the 97 evo stock cam? I'm switching to the EV-27 and was just wondering if I'll see a difference in power..........
Old Apr 20, 2008 | 04:43 PM
t150vej's Avatar
t150vej
Default RE: 97 evo cam
.472 lift, duration 208-201 (int./exh)
Yes, you'll notice a big difference with little or no tuning adjustments. And don't be disappointed if you have a bit of valve noise, some do some don't
Old Apr 20, 2008 | 09:48 PM
fripple's Avatar
fripple
thank you sir for the reply
Old Apr 21, 2008 | 07:53 AM
rivercityslim's Avatar
rivercityslim
ORIGINAL: fripple
Consider the Wood 6 (ballpark equivalent to EV27). check the 'Cam Choice' thread: https://www.hdforums.com/m_3228446/tm.htm
Old Apr 21, 2008 | 09:06 AM
fripple's Avatar
fripple
Should I replace the lifters while I"m at it? The bike has around 9k on it.
Old Apr 22, 2008 | 02:13 PM
mp's Avatar
mp
ORIGINAL: fripple
I would. Evo lifters are a known weak point. Yours would probably last for quite a few miles yet, but why not do it while you're in there? I had two OEM lifters fail in 100k. I have Crane now.
Old Apr 26, 2008 | 08:41 AM
phat96's Avatar
phat96
You might as well, your already there. They don't need to cost much. I did the EV27 also.
HDF Tech
Engine Mechanical Topics
Dec 3, 2019 12:52 AM
Melling
Jun 19, 2015 06:26 AM
MJHJEA
EVO
25
Dec 20, 2012 05:00 PM
gsxrboy96
Mar 25, 2012 03:04 PM
gsxrboy96
Feb 11, 2012 10:58 AM
