Backfire
Old Mar 2, 2009 | 09:19 AM
roofer's Avatar
roofer
Default Backfire
I have a 1991 softail springer with 70,000 miles and I am getting a rapid backfire, it will idle fine but when I give some gas I get this rapid backfire anyone got any ideas Thanks for any help you can give me it has a stock carb on it only mods are a stage one
Old Mar 2, 2009 | 10:51 AM
t150vej's Avatar
t150vej
Vacuum switch hose broken or leaking, intake manifold leaking, throttle slide diaphram leaking.
If it's backfiring every stroke, could be a burned intake valve, but most likely an external problem as mentioned above.
Old Mar 2, 2009 | 11:34 AM
d_slat's Avatar
d_slat
sounds like you have one of 2 issues. either weak spark, or incorrect fuel mixture. check for good hot spark from both wires, make sure the plugs are good, check for intake leaks, and make sure the jets are all clean in the carb. This is assuming you didn't start having trouble after doing some kind of mods to it....
Old Mar 9, 2009 | 08:35 AM
roofer's Avatar
roofer
Thanks for the info I pulled off the right tank it was easier to get behind the carb to check the vacuum hoses, the manual shows the hose going to the vov and then to the voes mine goes directly to the voes and the hose is very hard and on the left side of the carb the other vacuum is capped is this normal
marko69
Apr 1, 2020 02:53 PM
harleyrider0249
EVO
14
Mar 27, 2017 07:38 PM
dieseldoc
Carburetor Related
Apr 17, 2013 07:41 PM
danrider44
Engine Mechanical Topics
Sep 1, 2011 06:29 AM
DeputyDog605
Exhaust System Topics
Apr 25, 2007 08:04 PM
