Upper end Ticking
Old May 28, 2009 | 10:43 PM
davsel's Avatar
davsel
Stage III
I had a knocking / clatter noise in my 2009 Street Glide that kicked in around 2000 rpm up to 3000 rpm. I finally traced it down to a loose breather bolt holding the air cleaner onto the motor. the vibration set off the noise in a narrow rpm range. Just a thought that might help someone out - it may be something simple. Also, mechanics stethoscopes are cheap (around $15) and really help determine where suspicious noises are coming from.
Old May 29, 2009 | 09:39 AM
Milan's Avatar
Milan
Originally Posted by Red98RoadKing
Well I feel your pain. I've had a lot of help here but I'm about ready to get another engine. I've replaced the lifters, pushrods, rocker arm, checked side play in the rocker stand, instaled heavier oil pump spring, tried different weight oils upto 70 wt and still no fix. It will be quiet until it warms up then ticks like it has not enough oil pressure to keep the lifter pumped up. I've cleaned the oil passage screen the lifter block doesn't look worn.it has the noise coming from the front head and right at the exhaust rocker. AAAArrrrgggg!
Do you hear the noise at idle? I'm having the same problem and cant find the culprit. No noise at idle or accelerating just at cruise.
Milan
Old May 29, 2009 | 12:14 PM
Red98RoadKing's Avatar
Red98RoadKing
Okay boys and girls I might have figured it out and if this it I'm going freakin off on something. Last night I figured I'm going to pull the heads and get after it but I had an oil leak somewhere around the oil pump every since I put the heaver spring in. So for Sh*ts and giggles I put the stock spring back in just to see if for some strange reason it was causing the leak. Well it did stop leaking down to a weep and the top end wasn't near as noisy at all. I have a oil guage on it that came with the bike and I think its been reading way high this whole time. The logic is if the pumps weak to start with, putting a heavier reg spring probably lowered the oil flow even thus causing the lifter to sound like it had a starvation problem (which it would). Gotta find a new guage to check it with but if thats it....
Old May 31, 2009 | 07:09 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The oil goes through the lifters before it gets to the oil pressure regulating ball/spring…Even if the ball does not unseat, the lifters will get oil. When there is enough pressure to unseat the ball, it allows oil to the bottom end of the engine.
Mattbastard
Engine Mechanical Topics
19
May 14, 2018 04:19 PM
89FLHTC
EVO
45
May 13, 2016 02:31 PM
jrscars
EVO
Jul 19, 2013 09:58 PM
todsho
Exhaust System Topics
Apr 15, 2013 04:38 PM
bikerdan128
May 25, 2009 07:25 PM
